Adjustable Shaft(for measurement)
jdm2008
Industrial
I am looking for an adjusable shaft to measure the perpendicularity of a hole. The problem is that the hole can varry in diameter by quite a bit(.015).
The same concept is used in a bore mic but I do not need to actually measure the hole.
A set of gage pins is the usual approach - i.e. pick the tightest/best fitting pin and go from there.
Many bore gages can be mechanically locked to hold the reading. Sounds like that is exactly what you are asking for.
