The following was posted on the UGS usergroup of Solid Edge by Aditya Gurushankar (a SE developer) with regards to adjustable assemblies.
"In the assembly that you want to make adjustable, make sure the base part
is grounded and not constrained to reference planes/sketches/coordinate
systems etc. Also, ensure that other parts in the assembly are not
constrained to reference planes/sketches/coordinate systems etc. Reference
planes etc are considered fixed geometries and parts constrained to them
will not move as expected. Ground constraints in an adjustable sub-asm are
ignored, so it is ok to ground the base part. This is the most common
problem users face.
- With adjustable sub-assemblies, the sub-assembly itself is not being
positioned. It helps to visualize that the parts and relations under the
adjustable sub-asm are solved in the context of the top assembly. If you get
a inconsistent model, it helps to review the relations with this in mind.
Luc - Adjustable parts in an adjustable assembly was supported starting SE
v18.
Hope these help,
Aditya Gurushankar
SE Assembly Development"
Solid Edge V19 SP1 on WinXP SP2
