Yes, that is what I believe happened so that they could develop there "General" axial load capacities for various columns. I don't like it because all loading is different and all eccentricities are different. I use a simple spreadsheet to calculate my eccentricities based on bearing width of beam on post and loads and sum moments about the center line of the column and then get my eccentricity that way...pretty simple and very quick to do when dealing with really large beams and small ones too. The tricky part is when you start getting bi-axial eccentricity.
