About Column Least Dimension 1
dr. rifat
BD
Hello Engineers,
For G+10 storied concrete building is it correct to choose column least dimension 12 in?? Some expert says for 10+ storied rcc building it is best to choose column least dimension 15 in.But my structure says it is satisfied in 12 inch.
N.B.=My column sizes are
(12 in x 30 in)
(12 in x 36 in)
(12 in x 24 in)
Whats your thoughts/comments??
RIFAT
What is the tributary or column to column distance?
Also, what is the occupancy?
About 180 sft for 12 in x 36 in columnn,live load is 80 psf.
RIFAT
If it will be constructed in a seismic region, in my opinion I would require to increase those sections.
Because I think those sizes won't satisfy drift requirements.
Then whats your opinion??
RIFAT
increase the sizes and check all the necessary code requirements to be satisfied.
12 inches is a very small column.
faq731-376
That means we have to choose minimum 15 inches least dimension.
RIFAT
12" is a relatively small column width for a multi-story building. Not sure what your story-story height is but I would make sure the column width meets minimum KL/r requirements.
I don't believe there is enough information for anyone to make a sound judgment.
BA
Be sure to check that fire design is satisfied.
I'd suspect you'd struggle making 250mm wide columns work, unless you increase the length by a minimum of 4x the width (ie 1000mm).
In saying that you could have a column every 3m... the question really need more info...
