I want to conduct a parameter study for a design. The CAD model is designed in SIEMENS NX and then imported into the simulation software.
I want to change the value of one variable and see how the simulation result changes. Is there a way in NX to let the dimension take the value from an array and then export them?
An example would be, the thickness of a panel is denoted by d. I want the d takes value from 10 to 100 with a step of 10. And model of each d value will be exported in STP format.
NX version: 12
Thanks in advance.
Zhang Ze
NX version: 12
Thanks in advance.
Zhang Ze
