JStephen
- Aug 25, 2004
- 8,701
See the attached diagram. A larger beam is supported by two smaller columns, which in turn are pinned at the bases. When the larger beam is loaded, you get a certain amount of end rotation which in turn induces moments in the columns. The problems I'm running into are that when the height H is reduced, it actually increases the moment in the columns due to their increased stiffness. And trying to upsize the columns to the required strength just increases the moment.
The pinned connections are actually anchor points to a foundation. If one of those anchor points can slide about 1/16 of an inch, it eliminates the moment in the columns. Is it an acceptable design solution to assume that this happens? For that matter, if the the columns yield in bending, it shouldn't hurt anything. Any comments or suggestions here?
