I'm an engineer still learning about A/C. Two texts I've read state that installing a heat exchanger to transfer heat from the hot line between the compressor and condenser, to the cold line between the expansion valve and evaporator, will increase system efficiency. (at a minimum, having these lines run parallel and in contact with each other would be beneficial)
An installation manual I recently read advises against this however. Any elaboration on this subject, particularly as it relates to a home A/C installation, would be appreciated.
