I am designing a retaining wall for a residential client and wanted to hear some opinions about the type and method I am using. The above-ground height ranges from 9' to 2.5'; the wall is too close (less than 8') to the property line, so installing geomesh would be impossible without digging up the neighbor's yard. So the next obvious choice is a cantilevered wall (which the owner's want to be veneered with stone). I planned on the footing being concrete (of course, but I wanted the wall to be CMU blocks which is more constructable in this case (I think). Some other details about the wall include a 90 degree corner at the 9' elevation, and land slopes up behind the proposed wall by 15 degrees (east wall)and 25 degrees (north wall). To meet 1.5 FS for global stability, I need a 5' footer at the tallest section of the wall. The CMU blocks also have me worried; I may need to double-up the wall in some areas to help with shear and moment capacity in the wall. Is there a better way to design this? Am approaching this wrong?
