Our firm often uses #57 stone as backfill beneath footings when soft cohesive soils are removed, and high groundwater conditions exist. The stone layer thickness does not normally exceed 12 inches. If the adjacent soil profile consists of cohesive soils, the possibility of soil washing into voids in the stone is probably remote. If the surrounding soils are clean sands, this is a possibility. This can be prevented by requiring that the contractor wrap the stone layer with a suitable geotextile fabric (similar to an aggregate underdrain). Even if ravelling of soil into voids in the stone does occur, it would probably not undermine the footing, but may cause subsidence of the ground surface adjacent to the footing. We typically compact each 12-inch thickness of stone using 3 passes of a suitable vibratory plate type compactor.
