Koether
- Jun 20, 2007
- 10
For some drawings that I have been revising I have been trying to get away from re-inventing the screw and am just referring to ASME B18.3 (SHCS) for screw dimensions and tolerances when I can.
It was recently pointed out to me that ASME B18.3 requires the use of class 3A threads. This is a very common screw specification but it not common to see 2B threads called out for tapped holes. I have to think it is commonplace for 3A screws to be used in 2B tapped holes. Is this combination something that anyone has thought about? Is there any literature that discusses this?
The difference between 2B and 3B is only on the max side so I think that means the allowance should be the same between a 3A/3B and 3A/2B interface (potential for no allowance).
