2D to 3D Sketch conversion 3
Ripper2009
Nuclear
Jul 17, 2007
101
I would like to convert a 2D sketch into a 3D sketch.
I want to create a 90 deg. frame , but all I have is a 2D sketch, is there a quick way to change it to a 3D sketch or should I just start over?
Thanks in advance!
Thanks,
Rip
SolidWorks 2007
SP 4.0
Is it an DXF? If so, look up convert 2d to 3d in the help files.
From your question, I'm guessing that's not quite what you want to do, though.
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
You could always start a 3D sketch and convert entities.
Regg
Use the 2D to 3D sketch toolbar in SW... that is exactly how ot makes your 2D file (dwg DXF) into a 3D model. Most people here say its hard to use, but really after you understand how to use it, its not that bad to use.
There was a post on this subject just recently, but I can't find it.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
JM, SB, Reg,,...thanks!
I appreciate the help.
Thanks,
Rip
SolidWorks 2007
SP 4.0
I went ahead and made and AVI file of this. So maybe others will see its much easier then most people think. The model I used was very basic and the sketches did not need to be clean up either so this example was very easy. But the concept is exactly the same.
To view the file, please download and install the codec:
http:\\
Best Regards,
faq731-376
