For those wondering if 2020 could get any worse
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Here is one of Edenville Dam.charliealphabravo said:Has anyone seen a video of the failures? I'm surprised I can't find one considering how closely they were being monitored.
human909 (Structural) 21 May 20 00:48 said:As far as I am aware the Sanford Dam hasn't failed yet. But it is overtopping so it is likely a matter of time...
Fuse Plugs are pretty common on smaller dams, but they are on larger ones too. Its usually an earthen berm across a low spot along a spillway. It acts as an automatic natural "gate" that will be "opened" (eroded) once the water either erodes internally or overtops. Then the spillway can pass more water. It's a technique to help manage outflows during larger events. Common lower rain events may not trigger the fuseplug to activate, which will spare downstream innundation when its not necessary.Phil1934 said:They can't see what is gone from Sanford dam until the water level drops, but this feature makes no sense. "However, Sanford Dam's "fuse plug" — a spillway feature designed to wash away in high flood conditions to keep the dam from collapsing — has been washed out."
LittleInch said:The initial edenville dam failure looks like a slope failure to me - see the video earlier posted by human909
Concrete cannot effectively erode, so it was not the fuseplug. The concrete spillway appears to have a soil cover based on aerial imagery. This soil would act as the fuseplug. On-the-ground photos will help establish that. I'm sure some of this is available through FERC.LittleInch said:I suspect the fuse plug was that concrete structure but it only works if it is not completely destroyed by the water.
