I am detailing some 12" wide masonry shear piers (3'-4" and 4'-4" long) that are semi-highly loaded. Therefore I am concerned about grout and reinforcing continuity. As I am sketching them, I am having a hard time maintaining cell alignment around corners. Is there a special 'L' shaped block that is an odd length (20"
that is used in order to tooth the blocks? Do I need to call out for removal of face and end shells to allow for grout flow?
Thank you for your help.
