1. What is the procedure of designi
A.F
41
1. What is the procedure of designing single pile subject to moment and shear(example ultimit moment 2600 Knm, shear 100Kn, axial 200Kn)
Have a go, post your work and we will have a look. No one is going to do it for you
proposed procedure was the target not doing the work.
Evaluate pile internal forces using P-y analysis, Brom's method, or nomographs (e.g. NAVFAC). Compare to desired pile section capacity.
Evaluate pile tip deflection and rotation, and compare to allowable limits.
Iterate length or size of pile as needed.
ok, propose your procedure then and those that can help will. You have to make some effort.
If you come with a problem, you should always come with a solution. Even if its a bad one, its something
Dear Lomarandil
Searching underway for the method.
very helpful
