Axis deletion in Etabs 20.3.0
Shokoufeh
DE
Hi everyone
I've recently faced a problem during working with CSI ETABS 20.3.0. I wish that you can help me with that. Although "Lock Onscreen Grid System Edit" is on and grid lines are impossible to select individually, while I select beams (1 or more) and the window selection rectangle consists of grid lines (no matter the selection type is from right to left or from left to right), also grids are not visually selected, but if I delete element, some of the grid lines may be omitted, too.
I have to add that this happens sometimes, not always.
I wish you could help me with that.
