Sorting Load Combinations
StructuralAddict
CA
Is there a way in SAP2000 to sort the load combinations? The load combinations are always sorted by the time I added them. However, I want to sort them alphabetically based on the combo name I provided. I'm using SAP2000 v.23.3.1.
Thanks.
I don't see any way to sort them. Unlike in Load Cases, there's no up and down arrows.
I thought I might be able to sort them under Edit, Interactive Database Editing. I didn't see load combinations in there, though. Maybe if you try this, it'll work.
Thank you, but unfortunately, it didn't work as I couldn't see the load combinations in there as well.
My only other idea is to export to a text file, edit, and import.
If I did that, I'd feel the need to check everything again in the GUI, though. Thus, I'd probably just type them in again in the GUI. Maybe save as a template to hopefully avoid the same problem.
Irritating!!!
