modal analysis in ANSYS Mechanical APDL 2020 R2: How to see graphical results without mesh/elements
andradesilva
Materials
PT
I am doing a modal analysis in ANSYS Mechanical APDL 2020 R2. I would like to see the graphical results, namely the mode shapes, without mesh. How can I do it? By default, the mesh is always loaded into my results.
I thank you in advance,
For APDL-
Check Utility Menu>PlotCtrls>Style>Edge Options. Or you can use /edge command. Search Ansys help manual for more information on this command
For Workbench-
Go to solution and click on any displacement/stress result output>Edge button under result tab>No wireframe.
