Modeling clamping effect in SolidWorks FEA
Anurag K
I am currently running a FEA analysis on a plate for my project where a block is clamped to one of the free ends of a 100mm thick plate. How do I model the clamping effect accurately in SolidWorks FEA?
I made a few attempts -
Attempt 1
I modeled the block as a remote mass and gave it higher CG in Y axis (straight up). For area of contact I made a split line area and connected that remote mass to the area and applied gravity, it gave me a max deflection of 60 microns.
Attempt 2 -
I made same set up but did not use split line area instead I connected the remote mass to the entire of area of plate (the top face)
I have attached a picture for reference with front and top views (bottom two views next to each other)
Thank you for taking the time out of your day to read this post.
Method #1 seems like a good start. Have you done any hand calculations to see if that 60microns is reasonable?
The mass should be applied only to the region to which the block is attached. Instead of a remote mass, you could use a distributed mass.
