Change color of object without crashing if no object selected 1
cpetersen
I have a journal created that works to change the color of a selected object. I want to use this code in another journal that does a number of other things also. The problem is that I want the user to be able to press escape to choose not to select an object without crashing the program. I get a Null tag not allowed error. How can I change the code so I avoid that error? Thanks in advance!!
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim ufs As UFSession = UFSession.GetUFSession()
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Object Display")
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = False
displayModification1.ApplyToOwningParts = False
displayModification1.NewColor = 193
Dim objects1(0) As DisplayableObject
Dim body1 As Body = SelectSolid()
objects1(0) = body1
displayModification1.Apply(objects1)
displayModification1.Dispose()
End Sub
Function SelectSolid() As Body
    Dim ui As UI = ui.GetUI
    Dim message As String = "Click on solid body."
    Dim title As String = "Selection"
    Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
    Dim keepHighlighted As Boolean = False
    Dim includeFeatures As Boolean = False
    Dim selectionAction As Selection.SelectionAction = _
       Selection.SelectionAction.ClearAndEnableSpecific
    Dim selectionMask_array(0) As Selection.MaskTriple
    With selectionMask_array(0)
       .Type = UFConstants.UF_solid_type
       .Subtype = 0
       .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
    End With
    Dim selectedObject As NXObject = Nothing
    Dim cursor As Point3d
    ui.SelectionManager.SelectObject(message, title, scope, _
                                    selectionAction, includeFeatures, _
                                    keepHighlighted, selectionMask_array, _
                                    selectedObject, cursor)
    Dim solid As Body = CType(selectedObject, Body)
    If solid Is Nothing Then
       Return Nothing
    End If
    Return solid
End Function
End Module
The easy way to do it in your current journal is to do the selection first and check if the return value is "nothing"; if so, exit the main sub (this will end the journal).
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module Module213
    Sub Main()
        If IsNothing(body1) Then Return
        objects1(0) = body1
    End Sub
        Dim ui As UI = UI.GetUI
            .Subtype = 0
        End With
            Return Nothing
        End If
        Return solid
    End Function
End Module
www.nxjournaling.com
Thank you very much!!!! That was very helpful, and I appreciate it!
Chris
