Contact US
Laser welding 0.5 mm thick stainless steel
Hello there. Hope this post finds you well.
I am welding 0.5 mm thick stainless steel using Fibre laser. I'm consistently getting a burn thru. My joint edges are prepared by Shearing. Any idea of how to weld 0.5 mm thick stainless steel without burn thru.
Best Regards
Waqas
RE: Laser welding 0.5 mm thick stainless steel
Hey Waqas,
Hope you are doing well!
Welding thin stainless steel (0.5 mm) without burn-through:
1. Reduce laser power.
2. Use pulse mode if available.
3. Slow down welding speed.
4. Maintain a steady hand.
5. Consider using filler material.
6. Back purge with inert gas.
7. Optimize joint preparation.
8. Practice on scrap material.
9. Monitor welding parameters.
10. Consider a shielding gas.
11. Inspect the weld for defects.
12. Seek professional advice if needed.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
