Filling with date on titleblock selected cell
javaxp
Automotive
Jul 14, 2014
43
I'm trying to write a journal to fullfill the Date on a titleblock selected cell. So, the user selects first a cell, and running the journal, the selected cell is filled with the current Date.
My trouble is to get the Table instead of the TableSection.
By now this is my current code:
Code:
Imports System
Imports NXOpen
Imports NXOpen.UF
Module blank_all_tabular_notes
    Dim theSession As Session = Session.GetSession()
    Dim workPart As Part = theSession.Parts.Work
    Dim theUI As UI = UI.GetUI()
    Public lw As ListingWindow = theSession.ListingWindow
    Public Sub Main(ByVal args As String())
        lw.Open()
        Dim numsel As Integer = theUI.SelectionManager.GetNumSelectedObjects()
        Dim selobj As NXObject
        Dim myTable As Annotations.TableSection
        Dim myCell As DisplayableObject
        Dim regDate As Date = Date.Now()
        Dim strDate As String = regDate.ToString("dd\/MM\/yyyy")
        Dim j As Integer
        For j = 0 To numsel - 1
            selobj = theUI.SelectionManager.GetSelectedObject(j)
            If selobj.GetType.ToString = "NXOpen.Annotations.TableSection" Then
                myTable = selobj
            End If
            If selobj.GetType.ToString = "NXOpen.DisplayableObject" Then
                myCell = selobj
            End If
            lw.WriteFullline(strDate)
        Next
        myTable.EditCellText(myCell, todaysdate)
    End Sub
    Public Function GetUnloadOption(ByVal arg As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
I will apreciate any help.
Javier
NX 12.0.2.9 MP14
I finally got the journal working.
The user need to select a cell from a table and then run the journal. It fullfills the selected cell with the UserName (or the current date).
Here is the code if someone want to use it.
Javier
Code:
Imports System
Imports NXOpen
Imports NXOpen.UF
Module fill_tabular_notes
    Dim theUfSession As UFSession = UFSession.GetUFSession()
        lw.Open()
        Dim myTableSection As Annotations.TableSection
        Dim myTableTag As Tag
        Dim j As Integer
                myTableSection = selobj
            End If
                myCell = selobj
            End If
        Next
        theUfSession.Tabnot.AskTabularNoteOfSection(myTableSection.Tag, myTableTag)
        myTable = NXOpen.Utilities.NXObjectManager.Get(myTableTag)
        '____________Fills selected cell with current date____________
        'myTable.EditCellText(myCell, strDate)
        '____________Fills selected cell with current username____________
        myTable.EditCellText(myCell, Environment.UserName)
    End Sub
    End Function
End Module
NX 12.0.2.9 MP14
