Fiber laser Machine Error Z plus Dead Stop Active
PankajGohel
AU
Hi My name is pankaj
we have 8kw fiber laser machine and we got this error multiple time. DO you have nay idea what it might be ?
Pankaj
The "Fiber Laser Machine Error Z Plus Dead Stop Active" indicates a fault in the Z-axis movement of the fiber laser system. This error occurs when the Z-axis, responsible for vertical motion, encounters a sudden obstruction or resistance, prompting a safety feature to engage and halt all movement. This mechanism prevents potential damage to the machine or its components. To resolve this, check for any physical obstructions, such as debris or material buildup along the Z-axis path. Inspect the motor, drive components, and limit switches for malfunctions. Additionally, review software settings and parameters related to axis movement. Clear any errors, reset the machine, and ensure the workspace is clear before restarting. If the issue persists, consulting the machine's manual or reaching out to technical support is advisable. Regular maintenance and proper calibration can help prevent such errors in the future.
