Aluminium Extrusion - Tapered Section
engineeringspread
GB
Tried searching google but struggled to find any information.
I am familiar with the standard aluminium extrusion process for constant section. I am wondering if there is a possibility to extrude a section lets say circular starting at 100mm diameter reducing to 75mm over an 8m length, maintaining a 5mm wall thickness.
I would be interested to know if this is possible and any references to the die design to achieve this.
with sailboat masts they do but I don't know the tolerances
Tapered aluminum tube is a thing.
It may begin as straight extruded tube.
Then tapered by other processes.
Constant wall thickness is probably hard.
I have seen progressive forming of masts then welded, but never seen a tapered extrusion.
I have noticed reference to variable geometry dies so was curious if this is actually possible.
engineeringspread,
A tapered tube sounds like a good application for welded sheet metal. The 5086 grade is fairly strong in the as-welded condition.
JHG
I called a leading UK extruder and was informed this process is not one they are aware of, so my guess is this isn't possible.
