You should know the distance between the pivots and the distance from the one pivot to the pin marked B. You know the angle of the slot relative to the baseline between the two pivots.
So, recalling that C^2 = A^2 + B^2 - 2 ABcos(theta) and you know C, you know A, you know theta you can calculate "B", the distance from the first pivot to the place along the slot the pin is. Knowing all three lenghts you can calculate all three angles; in this case the remaining 2 of which you are interested in only one.
