Hi everyone,
I have designed a small anti-backlash gear with a module of 0.8 and a mesh diameter of 40mm. The anti-backlash feature is achieved by splitting the gear in two and adding a torsion spring between. The gear will transfer 0.45 Nmm torque at about 90 RPM.
I am looking for help calculating the efficiency of the gear transmuting the torque to a similar size gear (without anti-backlash quality).
Would anyone be able to help me with this calculation?
Thank you in advance for your help!
