Recommendation of HVAC system
zoe221
Student
May 12, 2023
Recommendation of HVAC system for the comfort of professional buildings ? Radio sensor? Which ones do you recommend?
The choice of an HVAC system for professional buildings will depend on several factors, such as the size and configuration of the building, the desired energy efficiency and the available budget. It is important to work with a mechanical engineer or HVAC contractor to select the most appropriate system for the building's needs. In terms of radio sensors, there are several available on the market and the choice will depend on the type of HVAC system and the specific needs of the building.
Is that an AI generated response, Mariola?
Ohm's law
Not just a good idea;
It's the LAW!
I apologize.
Ohm's law
It's the LAW!
