Static Analysis of Optimized Model
Dani2323
Student
NO
Hi.
I have performed a topology optimization in Abaqus. Now I want to conduct a static analysis of this optimized model in Abaqus and plot a force/displacement diagram. What is the easiest way to achieve this? I have tried exporting the file as an .inp, but it only contains the geometry. There is another .inp file that includes the assembly, load, material properties, etc. Can I merge these two files together? Or is there an alternative solution
You can go to the Job module and use Optimization --> Extract to save the result of the optimization to the .inp or .stl file.
I have done it, but this inp file only contains the geometry consisting of many elements. There is no information about the load, boundary conditions, material properties, etc. If I have to do this manually, I have to select each element and specify the different loads and boundary conditions. Isn't there a way to retrieve information about the load, boundary conditions, material properties, etc., so that it doesn't have to be done manually?
This tool only extracts the surface mesh. You still have to convert it to geometry to be able to create a solid mesh and assign analysis features properly. The following tools can help with that:
- Plug-ins --> Tools --> STL Import
- Plug-ins --> Create geometry from mesh (the 3D Mesh to Geometry plug-in has to be downloaded and installed first)
- Virtual Topology: Combine Faces
Check the article "Meshing Complex Geometries in Abaqus" on the Simuleon blog, it discusses similar cases when only surface (STL) mesh is available at first.
