Mohamed haggag
I have Electric Motor 30kw operates with ABB ACS 550 VSD .. I Face Repeated over current fault when i increased frequency to 40hz ..which equals 1150 RPM ..where rated speed of motor 1500 RPM
THE MOTOR used to drive supplu air fan for AHU system ...when we operate the motor in low speed 900 RPM ..no problem happens and No fault appears ..Any one has explanation for this issue ?
