Wooden dowel Roll bender ?
Uralsk
ID
Is it feasible to make metal plate roll bender out of dowel wood with thick aluminium inner core?
Certainly. Why not? You would need to develop all of the engineering and details. Material cost may not be too much different between the wood and using more conventional steel rolls, though. Wear characteristics of wood are probably going to result in shorter machine life.
"wood" = hobby/hardware store hemlock, pine, birch or oak?
Putting the aluminum in the center wastes a lot of bending stiffness and strength. At least 50% is my guess.
electrical conduit with wood dowel jammed in, or with a mortar ooncrete filling might be WAY stiffer
Is one end of these wood dowels inserted in a wooden plate ?
