Worm gear zi
Shubhm139200
IN
I am working on a project of cutter profile for zi worm. Also referred some research paper but not getting answers please any one can help me to understand the zi profile calculation please
Thank you for reply
I actually read that but there are not give information about zi profile cutter(how can get x,y,z coordinate for zi) and how to calculate for 2 start worm (I am new in this so I have no idea about it so pls help)
shubhm139200
what type of cutter it makes a difference.
see appendix A of agma 6022 page 10 6022-c93
[URL unfurl="true" said:
https://www.eng-tips.com/viewthread.cfm?qid=483497[/URL] spigor (Mechanical) 28 May 21 12:28]BTW I calculate this assuming a ZI worm
Spigot thank you for reply
I read all previous discussion but still i not get profile for cutter can you please describe me in steps for ZI as you mention in ZN
I'm working on whirling cutter profile for zi and in these two threads formulas are not give for calucalat zi cutter please help
Let's see what we can do. Where are you located in?
I referr some book for basic information and also read those trends but I have some questions regarding it
1) same formula for zi,zn and zk profile?
2) how to calculate points for tool?
3) can anyone please explain me how to calculate for tool
I can share some details of zi worm
Center distance =50.80mm
Reference diameter =24.76mm
Overall diameter =32.38mm
Root diameter =15.82mm
Base diameter =9.54mm
Addendum =3.81mm
Dedendum=4.4744mm
Axial pitch =11.969mm
Tip width=2.86mm
Normal pressure angle =20
Axial pressure angle =20.13
Transverse pressure angle =67.20
Lead angle =8.45
Base lead angle =21.45
I've looked and haven't found formulas. The most I've seen is a listing of the deviation of a perfect straight line for different sized teeth and different lead angles. But they only give 3 points: beginning, end and middle.
