Factor A in Asme section ii , thk for External Pressure
Hi
i could not extract factor A from tabluar values figure G
Material from table HA-1
D/T=69.7
L/D=50
1-A=?
2- if there is not same D/L according to L/D how shall be do , forexample in above there are 50 in L/D 60 and also 80
Ex: D/t=20 , L/D=40 A=0.275-02
D/t=22 , L/D=40 Whats A ?
D/t=25 , L/D=40 Not in Table
D/T=69.7
L/D=50
1-A=?
RE: Factor A in Asme section ii , thk for External Pressure
Often more convenient to just pick the values off of Fig. G if a "high degree" of accuracy is not needed.
For your first example, Do/t at L/Do = 50 is about 70, A is about halfway between 0.00015 and 0.0003, roughly 0.00023. A reasonably good clear platic scale is useful here.
Mike
If you want a more exact value you will have to interpolate between the ones listed in Table G. Given that Figure G is clearly log-log, you should consider using log-log interpolation for the most accurate value of A.
Dot = 69.7
LDo = 50
A = 0.0002410
I use an excel formula to index the tables I have in excel, then interpolate.
linear 0.23 or 0.24 ? and if log-log interpolate be accurate so what is the final result ? in somewhere i saw cal for 69.7 & 50 >>> 0.25-03
Example for first row (natural logs):
Do/T = 500, (log=6.2146), L/Do = 0.231 (log=-1.46534):
log(A) = -0.4385-(-1.46534+1.60944)/(-0.91629+1.60944)*(-0.4385+1.19733) = -0.59625
This would give (excluding the factor 10^-3) A=exp(-0.59625)=0.551 , quite different wrt the linear interpolation.
please define whats 1.19733 in above Eq ( is there mistake ??? - should be 1.1874 instead it or this is right in Eq)
D/t = 500
L/D 0.2 0.4
factor A 0.231 ?
factor A 0.645 0.305
- Interpolate on the Do/T line above to get the value of A above at your L/Do.
- Interpolate on the Do/T line below to get the value of A below at your L/Do.
- Interpolate between these two A values to get A final at your actual Do/T.
This is just one way of getting there. DO NOT just blindly follow my sequence. Think about it and convince yourself this is proper.RE: Factor A in Asme section ii , thk for External Pressure
in tabular values figur G section ii
60 80
0.306 0.172
Factor A General interpolation =0.24101-03
Factor A with exp(use ln in linear interpolation ) = 0.2267-03
Now which ones to be used ?
this one: Factor A General interpolation =0.24101-03
Ref UG-28 (c)(1), Step 4: It's your choice
EDIT: I recommend you perform the calculations using both values and observe if the difference is worth worrying about or not.
is Factor B in 750 F or 400 C degree
2750psi or 2903 psi ... i am afraid of wrong calculation manual
this linear interpolation is helpful for such type of issues.
