Contact US
APDL slows down
APDL slows down
APDL slows down
Hi everyone,
I have the following problem:
When I start a calculation with ANSYS APDL from some code, it starts quite quick and slows down a little bit while calculating. I see that at the speed in which it reads some scalar parameters / the speed in which the read scalar parameter are printed in the output window. Then, when the calculation finishes I use the
CODE --> apdl
/clear
command and execute the same codeagain. But the calculation time nearly double up to the first time for the exact same code. When I repeat this again, the needed calculation time increases again. But when I close APDL and open it up again. The calculation time decreased to the initial value. Can anyone explain why the program slows down so drasticly? I would be very thankful for any help.
Thanks in Advance!
RE: APDL slows down
Look to see if the memory being used by ANSYS is going up each time. It might be doing a poor job of releasing memory and instead of being all in RAM it's going to external storage which is slowing it up. When you quit ANSYS the operating system releases all the memory and starts fresh.
RE: APDL slows down
I have tested it and the used RAM does not increase while running the code. Any other thoughts?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
