Pneumatic pump
Pneumatic pump
Hello ! If I have a pneumatic pump connected to a fluid tank (fluid source), compressed air source (pressure source) and a closed tank full of liquid (output), can I increase my tank (output) pressure up to a value higher than my compressed air pressure?
Thank you in advance :)
RE: Pneumatic pump
If you mean another type of pump powered by an air motor then maybe - look at the pump curve or pump details.
You have somewhat economised on words / details so don't expect a lot of detail back....
RE: Pneumatic pump
No,, you cannot increased it. It will not pump anything
Horacio
https://www.linkedin.com/company/lagotuy/
RE: Pneumatic pump
RE: Pneumatic pump
MJCronin
Sr. Process Engineer
RE: Pneumatic pump
I ask a few people and usually they try to explain the faisibility through Pascal principle... I understand that we can increase force using a system with different surfaces, but the pressure remains the same!
Thank you once again
RE: Pneumatic pump
RE: Pneumatic pump
If you separate it into two systems you can have different pressures. The air side and fluid side are separated by a piston. If that piston has different cross-section areas for each chamber then the pressure can vary based on the ratio of areas.
Google "intensifier pump".
