Pneumatic pump
Peter C
Chemical
FR
Hello ! If I have a pneumatic pump connected to a fluid tank (fluid source), compressed air source (pressure source) and a closed tank full of liquid (output), can I increase my tank (output) pressure up to a value higher than my compressed air pressure?
Thank you in advance :)
If you mean an AODD pump then no. This assumes everything is on the same level. If the closed tank (why?) is lower then yes. But most "tanks" can only withstand a low pressure. Anything more than 15psi is usually classified as a Pressure vessel, not a tank.
If you mean another type of pump powered by an air motor then maybe - look at the pump curve or pump details.
You have somewhat economised on words / details so don't expect a lot of detail back....
Depending on the type of pump, yes. There are intensifier pumps that generate substantially more output pressure than the air supply pressure. But, if you're using an air operated double diaphragm pump the shaft is on the motor side of the pump which reduces the surface area of the diaphragm relative to the pumping chamber side. As a result, the maximum output pressure of an AODD pump will always be less than the supplied air pressure.
Can you take a couple of pictures and share them with us ???
MJCronin
Sr. Process Engineer
Dear all, thank you for your reply. I am sorry for the lack of precision, but I meant to do a more general question: if a pneumatic pump can increase a pressure vessel pressure to a value grater than the compressed air pressure. I feel like at some point the fluid pressure will reach the air compressed pressure, and there is no way to keep "sending" more fluid inside the vessel...
I ask a few people and usually they try to explain the faisibility through Pascal principle... I understand that we can increase force using a system with different surfaces, but the pressure remains the same!
Thank you once again
Define "pneumatic pump" please.
If you separate it into two systems you can have different pressures. The air side and fluid side are separated by a piston. If that piston has different cross-section areas for each chamber then the pressure can vary based on the ratio of areas.
Google "intensifier pump".
