Ditch Inlet
MD3
1
Recommended Ditch Inlet to support west 600 HDPE dia. pipe, east 450 mm dia. HDPE pipe and outlet pipe elliptical concrete 610 x 965
Can someone turn this into a legible question please?
If I am understanding it - there is a 600mm and 450mm HDPE pipe entering the structure on opposite walls and a 610mm x 965mm ERCP on another wall. A standard box size to accommodate this in my locale would be 1675mm x 1220mm. It would require a reinforced 200mm thick top slab with a "top unit" containing the inlet frame and grate on top of the slab.
MD3
What are the invert levels?
Flow rates?
Pipes full or half empty?
