plastic extruder barrel and screw made out of grade 7075 aluminium?
Uralsk
39
is it feasible to make plastic extruder barrel and screw made out of grade 7075 aluminium?
what problems would i experience if make plastic extruder barrel and screw made out of grade 7075 aluminium?
would nitriding or andodizing aluminium make it wear resistant for the plastic extruder barrel and screw?
i wanted to use grade 7075 alumimium because is more corrosion resistant lightweight and higher thermal conductivity than steel
It's been quite a few years since I've worked on extruders, but I don't
think aluminum would survive the cleaning process when things go wrong,
like a loss of power.
And Al has a low modulus so it won't be very stiff as well as a very high thermal expansion coef.
It might work as a short term expendable part.
I don't know what kind of temperatures you're operating at, but I'd also be concerned about the strength of 7075 (or any aluminum really) at elevated temps; you'd definitely have to understand the temperature dependent properties of 7075 at your operating temperatures.
