AWS D17.1 WELDER CERT. QUESTION
When looking at the tube to plate figure for welder certification, is it permissible to drill a hole into the center of the plate? We plan on using this hole to feed gas into the tube. There isn't anything in the spec that says we can't have a hole. Not to mention, once the test is cut up for evaluation, the hole won't matter I believe, as you're examining the weld.
If someone can provide some insight on this, that would be appreciated, thank you!
RE: AWS D17.1 WELDER CERT. QUESTION
Best regards - Al
