Contact US
Regarding spring element
Anyone has modelled spring element is SAP to get a vertical mode shape in Up and down direction? If yes, How to model those elements?
RE: Regarding spring element
What is a spring other than just a beam/column element? If it has equal stiffness in tension and compression, you can just make a custom material/section properties combo that gives you the correct stiffness of the spring. Add a mass and supports then you can do the modal analysis.
If your talking about foundation springs or something like that than perhaps I haven't understood your question properly.
Thanks for your explanation. Not foundation springs. I am modelling a cooling tower like structure. For that spring elements are needed
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
