Is *MAT_059: MAT_COMPOSITE_FAILURE_SHELL_MODEL applicable to TSHELL element in LS-DYNA?
Does anyone know whether we can use MAT_059 with TSHELL element in ls-dyna? I saw an introduction slide saying that MAT_059 is compatible with shell,tshell and solid elements. However, I have tried both two types of MAT_059 with TSHELL element and the solver always told me that the section type (SECTION_TSHELL) is incompatible with MAT_059. Does anyone know this? Thanks!
RE: Is *MAT_059: MAT_COMPOSITE_FAILURE_SHELL_MODEL applicable to TSHELL element in LS-DYNA?
You can find lot of information in LS-DYNA Manual R13.0 Vol I and Vol II. E.g. Vol-II, Section MAT-059
