Remove Casing / Disassembly Option API 610
On an API 610 datasheet, the option for "Remove casing after test" is shown with the option for non-witness/witness. What does that mean exactly? Is it referring to removal of the casing cover for visual inspection / complete removal of water in the pump casing?
Would this be an option to avoid complete disassembly of the pump after testing?
RE: Remove Casing / Disassembly Option API 610
