Let's say I have a round bar with Datum A defined as the center axis. Then I cut the bar at an angle, and make this angled surface datum B (inclined datum). Do Datums A and B comprise a fully constrained datum reference frame for additional features, or is a tertiary datum required?
In the example attached, is the thru hole fully defined in orientation about datum A axis, simply with the Datum B reference and no tertiary datum?
A constrains translation [x,y] and rotation [u,v] and B constrains translation [z] and rotation [w]. All 6 DOF are constrained, think about it physically as DOF constraint is driven by the physical realities of the geometry involved. If you put the rod inside a hole that simulates A and then up against an angled surface which simulates B, will you have any free DOF? How well/reliably B actually constrains rotation is another matter, which is affected by the diameter and the angle of the face (ie: a very shallow angle or a very small diameter will not constrain it reliably) however for your size rod at a 45deg angle it might work reasonably well.
Also small note, datum A is not defined as the center axis (ie: thats not what the datum feature symbol is pointing at, which defines your datum feature) - it is derived from the OD datum feature A (or technically its inverse datum feature simulator). We can talk about the theoretical datums, but its good to always remember the physical geometry from which it is derived. It may seem like I'm nitpicking, but its an important distinction.
Thanks chez311 that explains it very well. As you mention I think the caveat is if the surface is at a relatively small angle it might not do a good enough job of constraining the rotation, depending on your requirements.
If precision in the inclined feature relative to the hole is required then the hole would make a better reference to hold the part while the incline is made. One difficulty in evaluating such things is that analyzing the practical effect of such variations have on the operation in use. It might be a concentrated stress or a flow control that is the limiting factor over simple geometry.
Thank you for helping keep Eng-Tips Forums free from inappropriate posts. The Eng-Tips staff will check this out and take appropriate action.
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Metal 3D printing has rapidly emerged as a key technology in modern design and manufacturing, so it’s critical educational institutions include it in their curricula to avoid leaving students at a disadvantage as they enter the workforce. Download Now
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
RE: Cylindrical Feature with Inclined Datum
