Contact US
GEC Electric Motor 256/180
RE: GEC Electric Motor 256/180
(Cap size in microfarad) = {(ENERGY in joules) / [(0.5) * (Volt) * (Volt)]} * 10^6
For Start Cap, use START ENERGY (Start caps are generally somewhere between 50 and 150 uF)
For Run Cap, use RUN ENERGY (Run caps are generally somewhere between 5 and 100 uF)
Converting energy to motion for more than half a century
There is not enough information for an accurate calculation but the estimate can be found here (approximate value of start and run capacitors for single-phase motors, 230 V; 50 Hz) :
https://winding.wixsite.com/design/for-customers
Thank you to all for your help.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
