Contact US
Tolarance analysis
Tolarance analysis
RE: Tolarance analysis
Well what is it you want, there is no description of what you are trying to do.
What I want is to find the worst-case tolerance for X which has a nominal value of 8.19
Okay so your post doesn’t mention 8.19 but I guess at 8.19 the pins will still fit in the holes, so with your holes on minimum diameter and your pins on maximum diameter workout the centre distance that the pins will still fit and then do the opposite, work out hole centre with pins on minimum diameter and holes on maximum size, this should give you the tolerances for the X dimension.
Note the end of your block is less than a 1mm from the centre of the pin hole on the right hand side of your sketch.
thank you much appriciated
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
