Hi Engineers How to weld clean ou
Hi Engineers
How to weld clean out door base plate with annular plate? What is the welding procedure?
RE: Hi Engineers How to weld clean ou
Dan - Owner
http://www.Hi-TecDesigns.com
MJCronin
Sr. Process Engineer
Tank Details:
Dia : 200 ft
Height : 48 ft
COD Base plate Thickness : 34mm
Annular plate Thickness ; 14 mm
As in our case, we are going to only replace the bottom reinforcement plate (or annular plate) of the clean out door.
Does we have to stress-relief the whole clean-out door assembly afterwards? or just PWHT of the new welding of the new annular plates to the new door reinforcement plate?
Or, in this case, is not required.
Please advise me.
