2cool4school
Chemical
Good day All,
I am currently installing a HRSG boiler on a CHP plant. The designer opted for SS304L as the material of construction. Due to the high chloride levels in the water we decided against SS as it is prone to SCC.
When we asked the designer to switch to CS (A106 B) the claim is that aluminum fins cannot be used now due to the PWHT required on the tube to tubesheet welds. This is according to ASME BPVC SECTION VIII Part 1 UCS-56-1.
The lack of fins is increasing the area required for exchange by 230%
Is the designer interpreting the code correctly?
Tubesheet 25 mm
Tube diameter 25 mm
Thanks in advance
Tubesheet 25 mm
Tube diameter 25 mm
Thanks in advance
