The stress on F&D head is extremely high in ANSYS Workbench as compared to ASME VIII Div-1.
Issue: The stress on F&D head is extremely high in ANSYS Workbench as compared to ASME VIII Div-1 calculation.
Vessel OD: 96”, 106” Seam-Seam
Thickness: 0.4375”
Pressure: 105 psi
Material: SA-24 316L.
The baseplate of Leg as fixed.
I did ANSYS analysis for F&D (ASME 80:10) head. The obtained Eq. stress was 35,000 psi (Membrane stress: 25k) which is extremely high as compared to code calculation. Code calculation gives 14,000 psi.
I performed a similar comparison with the 2:1 Ellipsoidal head. The ANSYS Eq. Stress was 18,000 psi (Membrane Stress: 12,000 psi). This is close to code calculation, code calculation gives 11,500 psi stress.
Also, there was high stress (30k psi) in SUPPORT LEG for the F&D head and just 9k in the ellipsoidal head.
The setup and procedure of analysis were the same for F&D and Ellipsoidal head but there was a high deviation from the code calculation in the case of F&D head while analysis of Ellipsoidal head is in line with code calculation. What can be the cause of deviation in the F&D head?
PS: I have ignored stress concentrated at a point due to singularity.
Thickness: 0.4375”
Pressure: 105 psi
RE: The stress on F&D head is extremely high in ANSYS Workbench as compared to ASME VIII Div-1.
May I suggest you take a look at this paper for some additional formulae.
It has tables and graphs of the principal stresses in the knuckle and crown on the inside and outside surface for all sorts of t/D, KR/D, CR/D. From standard ASME Tori's to 2:1 Ellipses.
