On how and where to insert command snippets inside Workbench mechanical
IJR
TR
I am looking for a good reference on where and how the command snippets need to be inserted inside a Workbench
mechanical tree. I do this all by trial-and-error. This one rejects the hacker-style method of learning stuff.
I am not seeing progress at all. Help is needed.
Any input will be highly appreciated.
ijr
In the tree if you select and right click on any of the solid under geometry---->Insert---->Command.
Thanks Saikahirpara
But I was actually looking for the associations between a given command and a branch in the tree itself. Not every command goes to the geometry branches.
I can not find that in the manuals
ijr
