Discarded Area Increases Volume and Rate For Small Storm
I am modelling a small project which is producing unexpected results. The flow path consists of a blacktop driveway. Tributary to the flow path is a small area of grass, some roof water, and of course the driveway. Post construction eliminates the grass area and all new impervious and existing roof water is directed to an infiltration bed. So, even with less catchment area tributary to the flow path I am still seeing an increase in both rate and volume for a 2 yr storm. All other storm events produce expected results with a slightly lower volume and peak rate. Please see attached files, Thanks
RE: Discarded Area Increases Volume and Rate For Small Storm
Peter Smart
HydroCAD Software
www.hydrocad.net
