Contact US
Thread's chamfer size
Hey everyone,
I wonder if there is a standard or a common rule in which I can find what should be the chamfer size in a male (outer) and a female (inner) thread.
I remember that I heard that what matters is the pitch size, and by knowing it we can determine the chamfer size.
RE: Thread's chamfer size
I think the rule-of-thumb was that, in the case of a male thread, that the flat area was equal to the minor thread diameter. For a female thread, it was that the outer diameter of the chamfer would be equal to the major thread diameter.
John R. Baker, P.E. (ret)
EX-'Product Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
One common rule for tapping is to chamfer to a diameter = screw thread major diameter.
On hardened materials you need to counter bore a couple thread leads to prevent thread tear out on the edges...
Counter-bore or counter-sink?
Irvine, CA
Siemens PLM:
UG/NX Museum:
Bad link...
Irvine, CA
Siemens PLM:
UG/NX Museum:
It seems there isn't some definite rules, at least based on the varied answers.
mfgenggear - thanks, I read it carefully but it seems that these chamfers can be afforded when you have a lot of threaded length, but when trying to use these rules when you have a short nut - about third of it is "wasted".
elinah34
sorry about the broken link. yes the typical for lead in on holes is 1-1/2 threads, for a nut depending on the width it varies.
most of my customer had their own internal requirements. for tapped holes I would use a counter sink , external threads a chamfer.
generally rule of thumb as well as others said internal thread minor diameter plus .015-.020 per surface. in your case need to evaluate
and leave enough threads for strength. I would suggest a small counter sink to assist with the tapping cycle as a lead in.
elinah34,
What is the context of your question?
Any time I drill and tap a hole, I use a bigger tool, usually a drill, to clean up the edges of the hole. I do this fairly quickly by hand, and I check it for burrs, not dimensions. I don't know what real machinists do. I have never had cause to worry about it.
Your drawings should specify that sharp edges and burrs must be removed. If you want to call up a chamfer, call up something that meets your requirement.
JHG
I have a low profile 10-32 manufactured nut, and its height is about 3 mm. If you calculate how long the thread is if we follow the guidelines above we will be left with a short thread - less than 3x lpitch
elinah34,
If this is a nut you are designing, you need to control the number of threads. Perhaps you need a section view specifying the minimum effective thread length. Perhaps you need a thicker nut. Perhaps you need to calculate and specify screw torque. Perhaps you need to specify a high strength material for your nut.
JHG
I agree with Drawoh left out important information. the reason to chamfer or counter sink
lead in for tapping or threading
if no break a sharp thread will be present, and subject to damage
.118 inch (3 mm) thickness may not be sufficient, depending on the application.
OK if we may ask why is this nut so thin.
mfgenggear and drawoh - thank you for your answers. I have a limited space (I have no access to my CAD, since it's in my work's computer, and that's why I don't add a cross section photo for explaining better) in which I have to adjust a custom nut...that's the reason I need a 3 mm height 10-32 custom nut. I know it's not ideal, and I hardly have 3 threads participating in the tightening - but this is a constraint I have to deal with. So limiting the torque might be the compromise.
Is the only aim of the countersink in a threaded hole is easing the engagement of the threads (male and female)? If the answer is yes, I guess the countersink size isn't that important...
The countersink is not essential, but it does greatly ease the alignment of parts for engagement of the threads and removes the fragile parts of the thread that get easily damaged.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
