stress analysis fundamentals
folks,
so I have been told by my seniors my fundamentals are weak.. and to an extent I agree with that.
I want to get better and increase my stress analysis fundamentals knowledge. Could you guys please advise where I can start? flabel? bruhn?
if yall have any pdfs etc.& are willing to share, I would really appreciate it.
RE: stress analysis fundamentals
I am not sure what fundamentals you want to build, so just doing hand-calcs from a textbook may not be the answer.
Assuming that you mean aluminum sheet-metal and riveted/bolted connections most common in 20th-century aircraft production, have you ever driven a rivet?
Have you drilled the hole, matched it to another mating piece, torqued the bolt, and load-tested the assembly to failure?
It's amazing how many engineers haven't done that stuff.
How are your free body diagram skills? How is your familiarity with typical loadpath assumptions?
E.g. try freebody-ing a wing rib. Develop a shear and bending moment plot for it. Where would you take section cuts? How would you orient the section planes? How would you correct for flanges non-orthogonal to the cut plane? What failure modes would you check on the flanges... The web? The stiffeners?
Is that the sort of guidance you're after? Or something else?
Airframe structural design : practical design information and data on aircraft structures
Airframe stress analysis and sizing
Composite airframe structures : practical design information and data
Regards, Wil Taylor
o Trust - But Verify!
Your plan is to strengthen your stress analysis fundamentals knowledge.
Are you sure your plan is aligned with what your seniors are telling you?
Regards, Wil Taylor
Regards, Wil Taylor
